Activity Forums Maxon Cinema 4D a Double – Step time effector on a mogra
  • a Double – Step time effector on a mogra
    Posted by Elad Magdasi on August 31, 2017 at 7:31 am
    Hello all,
    Putting a step effector on a cloner and offsetting the time works. (in the example I attached it’s the material which is changing)
    However, if I put that cloner in another cloner, and put the same effector on it,
    It will calculate only the first step effector.
    So I can not create the effect I need.
    If I disable the step effector on the child cloner, the parent cloner will consider the step effector, but not both at the same time.
    Is there a way to overcome this limitation ?
    sample scene: https://www.dropbox.com/s/x0g67241a2iwx82/double%20step.c4d?dl=0
    Thank you in advance!
    Ghosteam.
    Steve Bentley replied 9 years ago 2 Members · 1 Reply
  • Steve Bentley
    September 7, 2017 at 11:17 pm
    Each cloner will probably need its own effector. If you share the effector any offsets can’t be calculated properly for both cloners at the same time.
