Activity Forums Adobe After Effects A decent 3D floor
  • A decent 3D floor
    Posted by Rob Wolf on June 16, 2007 at 8:05 am
    I’m beginning to venture into the mysterious 3rd dimension in After Effects and have been running into a problem doing something that seems like it should be easy:
    How do I get a decent looking 3D floor?
    I’ve played around with solids, and they work, but often have an abrupt edge, to matter how big I make it. I’ve tried playing around with depth of field, but that doesn’t seem to do enough to blur the background as it heads off into the horizon.
    I’ve also tried faking it with some 2D gradients, but those aren’t all that convincing, nor do they keep up once I start moving the camera.
    Any suggestions?
    Rob
    Darby Edelen replied 19 years, 3 months ago 6 Members · 16 Replies
  • 16 Replies
  • Steve Roberts
    June 16, 2007 at 2:41 pm
    You mean an infinite ground plane?
    It’s not something AE does naturally. You could consider applying Motion Tile to the floor, but if the layer gets too big, you could crash. The only option I’ve found (so far) is Aurora Sky, which may allow you to tile an image infinitely. I’ve never used the plug, so you’re on your own. 🙂
    https://www.digi-element.com/aurorasky/index.htm
    But I’d also consider rejigging the comp so an infinite ground plane isn’t necessary.
  • Virtual Light
    June 16, 2007 at 3:50 pm
    You can do it but it isn’t easy. I made a desert floor for a 3 minute 5-screen project for a museum. The screens represented the view from inside a 1920 railroad car (thus the sepia tone). The floor was constructed from a 16,000 pixel panorama. I cut the panorama into 130 layers–each one placed further back in 2D space with the loop speed adjusted and then soft masked to hide the seam. The most foreground loop plays in 8-seconds and each subsequent layer moves slower until finally the furthest layer barely moves at all.
    I’ve uploaded an example at https://virlt.com/floor.mov
    At this resolution (25%) you can’t really notice the detail in the furthest layers but they definitely show up in the final render–which, btw, took 8-computers 44 hours to render on AE7.
    jim
  • Virtual Light
    June 16, 2007 at 3:54 pm
    Sorry, but I noticed that the link won’t work from within this forum. Can someone explain to me why that’s the case? In the meantime, you can just copy the link to a new browser window and it should work.
    jim
  • Ron Lindeboom
    June 16, 2007 at 4:14 pm
    You have not set the permissions on the FTP’d file to allow the “public” to read it.
    That is why your audience is getting the “forbidden” notice.
    Best,
    Ron Lindeboom
  • Virtual Light
    June 16, 2007 at 4:37 pm
    Hi Ron, I don’t want to turn this thread into a discussion of links and ftp, but briefly, the file’s permission are correct and in 10 years, all clients have been able to access my site. Not sure what’s up but I do notice that you can paste the link manually in another window and it works.
  • Ron Lindeboom
    June 16, 2007 at 6:53 pm
    I suspect that your permissions do not allow your files to be “3rd partied” in their display — meaning that because they are being viewed inside our wrapper (instead of directly as when you open a new window and view the link there) they will not display.
    This disallows sites from sucking your files into them and highjacking your content. Unfortunately, it also disallows you from making a direct post to it such as here at the COW.
    That is what I suspect.
    Ron Lindeboom
  • Darby Edelen
    June 16, 2007 at 8:23 pm
    Just to be nitpicky, that’s not so much a floor as a series of walls 😉
    But in answer to the original question, you will probably need to use some sort of ‘wall’ to fake the horizon. If you look out at the real world, for example, there is rarely… no, I’m going to say it… never an infinite plane =)
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Virtual Light
    June 16, 2007 at 9:00 pm
    I never promised a rose garden. There’s no question that this IS a series of walls. Every other approach I utilized just plain wouldn’t work in AE’s 3D space. I tried to use HD footage but since the “train” had to come to a slow stop at the station, there was no way to time remap without severe stuttering.
    Jim
  • Rich Rubasch
    June 16, 2007 at 9:09 pm
    Hey Jim….I just added a www at the front of the link and it worked fine.
    Always a way…
    Rich Rubasch
    Tilt Media
  • Virtual Light
    June 16, 2007 at 10:04 pm
    thanks Rich…good to know.
