Activity Forums Adobe After Effects a CURVED LINE in after effects?
  • a CURVED LINE in after effects?
    Posted by Tom Gomez on June 11, 2013 at 5:49 pm
    Greetings AE Geniuses,
    I’ve got a project that has a bunch of objects floating around connected by LINES. Using the beam effect tied to positions or the shape tool with expressions I have no problem connecting the objects as they move around.
    BUT, now the client may not want lines, but curves. So instead of a straight line connecting the objects, I may need to do curves… Just a little bend in the lines so they swoop up. Dotted if possible.
    Any idea how to do curves that could change length as the objects move?
    THANKS!
    Tom
    YOU can help save TimeSpace. Join the Chronos Protectorate!
    https://www.95ers.com
    https://www.SpaceAceMedia.com
    Jason Jantzen replied 13 years, 2 months ago 3 Members · 2 Replies
  • Todd Kopriva
    June 11, 2013 at 6:04 pm
    https://motionboutique.com/connect-layers-1388
    After Effects team blog
  • Jason Jantzen
    June 12, 2013 at 9:14 am
    Connect layers is really fun and easy to use. Watch the 9 minute tutorial on that link Todd shared and you’ll be set to rock and roll. Just make sure you use the rope script. It uses rotobezier lines to give the curve you’re looking for. Basically it connects points that you can of course animate. The lines are shape layers, from which you can of course create dotted lines 🙂 Victory on all accounts!
    Jason Jantzen
    vimeo.com/jasonj
