Activity Forums Adobe After Effects A Couple of Questions
  • A Couple of Questions
    Posted by Aaron Silman on July 25, 2009 at 9:48 am
    i thought i had a pretty good computer, i thought it would be really fast, but when i got after effects its RAM preciew isnt working that good.
    For instance i bought Evolution from Video Copilot and when i get multiple layers of effects from in on my comp and RAM preview, its starts to render the preview, but it gets to a point where the green bar above the clip where it started Rendering starts moving, like it goes away, and is forever stuck in rendering the whole preview.
    Why is this happening?
    Second, how can i make After Effects Render better?
    here are my computers specs:
    https://reviews.cnet.com/desktops/hp-pavilion-a6750y/4507-3118_7-33529089.html?tag=mncol;rnav
    PS i did look in the AE facts about rendering preformance.
    Aaron Silman replied 17 years, 1 month ago 2 Members · 3 Replies
  • Stuart Elith
    July 27, 2009 at 12:29 am
    Not entirely clear about what you’re describing with the green bar. Are you saying that as you RAM preview, after a while it will stop adding to the RAM preview (shown by the green bar) and taking away the old frames that were RAM’ed? This happens when the computer can’t keep everything in the RAM preview, so you have to preview in sections. It happens.
    8 GB of RAM is great, but you only have a single processor, it seems (or is that a quad core?). AE can only use a certain amount of RAM per core (i think it might be 3GB?) so the extra isn’t being used. If it is in face a multiprocessor, you can go into the AE preferences and enable multiprocessing. I haven’t done this so i’m not sure how it works, but my understanding is that it will speed up your previews.
  • Aaron Silman
    July 27, 2009 at 3:27 am
    you are correct when decribing my green bar problem, it takes away previously RAMed areas to RAM the next part. Thanks for phrasing it in a way that more people can understand!
    And yes, my computer s quad core, i am going to try that multi core rendering that you said. Is there any drawbacks to using it? Also might just get nucleo pro 2, but it doesnt support cs4 yet.
    Thanks for the response.
  • Aaron Silman
    July 29, 2009 at 9:25 pm
    yes, i believe i am RAM previewing the correct way, i am pressing the arrow on the right side of the screen, i dont think there is any other way to ram preview.
