Activity Forums Boris FX Particle Illusion A couple of questions…
  • A couple of questions…
    Posted by Mandyyjobs on May 1, 2005 at 5:16 pm
    1) A while ago I saw a tutorial about using PI3 where a man was cloaked in flames that were created with particle illusion. Does anyone remember this and have the site url? I have a greenscreened actor, that I want to put splashes of rain on using this method.
    2) I am creating a scene with raindrops, but the scene is in profile, so all I need is the explosion of the drop as it hits the water, but from the side, so I don’t need to see the ripple circle or anything, just the jet of water shooting up. IS there an emitter for that?
    Thanks in advance!!!
    Mandyyjobs replied 21 years, 4 months ago 3 Members · 5 Replies
  • Elvis Deane
    May 2, 2005 at 7:03 am
    I’m not sure of any tutorials online, but that subject is covered in the help file, in Tutorial 4, under the subject Area Emitter Masks.
    Here’s an emitter that does the raindrop explosions. You may want to lower the Life of the Droplets particle type down to make it more realistic.
    https://pi.shockingtales.com/ipf/rainStrikes01.zip
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
  • Mandyyjobs
    May 2, 2005 at 11:07 pm
    Thanks, but the file doesn’t seem to work for some reason. I am using PI 3.0
  • Mandyyjobs
    May 2, 2005 at 11:47 pm
    Nevermind I got it to work. I am fiddling around with the setting, but I want alot more particles in this scene and I changed the number to over 1000 but it doesn’t seem to increase the number.
  • Alan Lorence
    May 2, 2005 at 11:50 pm
    Some emitters use special settings to determine how many particles are created.
    What emitter is it?
    Alan.
    wondertouch
  • Mandyyjobs
    May 3, 2005 at 12:18 am
    I am not sure, he just sent a file with it. See Elvis’s post for the file…
