Activity › Forums › Blackmagic Design › A couple of Decklink Extreme questions
  • A couple of Decklink Extreme questions
    Posted by Shawn Wyatt on October 12, 2005 at 12:16 pm
    I only have access to the simple controls under system preferences of my Mac to affect the video coming in (which does look that great). The controls under the log and capture of FCP are grayed out. Isn’t there a better way?
    I read one post that said they adjusted their proc amp (I guess that’s what it was) to 1.69 gain to get it right. My controls don’t seem to offer that kind of precise control.
    I also don’t have the option of going out SDI on the system preferences panel – I have it coming in as an option but not going out. Any ideas on what the problem is?
    Thanks for your help
    Shawn
    Luke Maslen replied 20 years, 11 months ago 3 Members · 2 Replies
  • Geir Ove thorsveen
    October 12, 2005 at 12:47 pm
    Under the Blackmagic Decklink controls in System Settings you should have a Proc Amp tab that will allow you to adjust Video Gain and Chroma Gain for your analog inputs on the BMD Extreme card. They are adjustable to 0.01 accuracy.
    The Blackmagic Decklink Extreme card will always output on both SDI and analog outputs, therefore the only option you have under Outputs is between Analog Composite or Analog Component. In composite mode it will output a PAL or NTSC signal on the Y connector, in component mode it will output Y, R-Y and B-Y on the respective connectors. SDI out will always be active regardless of the analog choices.
    Hope that helps some,
    Geir.
  • Luke Maslen
    October 14, 2005 at 6:46 am
    Wow Geir!
    That’s a perfect answer 🙂
    Regards,
    Luke Maslen
    Blackmagic Design
