Activity Forums Adobe After Effects A counting number along a curved motion path
  • A counting number along a curved motion path
    Posted by Scott.production on March 8, 2007 at 7:17 pm
    I’m not sure if my post went thru, as I had to sign up for the Cow while trying to send.
    In a nutshell: I want to have a number count quickly up (or down) while moving along a bezier-curve motion path. The example was: 4652 counts quickly by ones up to 5398 while it slides up a “mountain” along a bezier curved path. I can make the number count with the “numbers effect,” and I can make a number slide along a path (by pasting the curve mask into the position property of a text layer), but I can’t make either one do both. Any suggestions?
    scott.production
    Scott.production replied 19 years, 6 months ago 3 Members · 4 Replies
  • Mylenium
    March 8, 2007 at 8:04 pm
    Animate the source text paramter. You need a slight detour to do this.
    a) Create a text layer.
    b) Set all your parameters and assign the mask path.
    c) Apply an Effects —> Expression Controls —> Slider
    d) Alt+click the stopwatch for the source text property
    e) Apply this simple expression:
    Math.round(thisLayer.effect(“Slider”)(“Slider”))
    Animate the slider to change the value fior the text.
    Mylenium
    [Pour Myl
  • John Kaley
    March 8, 2007 at 9:03 pm
    Apply Effect/Text/Path Text to a solid.
  • John Kaley
    March 8, 2007 at 9:08 pm
    Ahhh-sorry, path text cannot animate the numbers!!
  • Scott.production
    March 8, 2007 at 9:23 pm
    Mylenium: Danke schoen fuer die schnelle Antwort. Problem geloest! Mein kleiner Erfolg fuer heute. Danke.
    Mach’s Gut,
    Scott.production
