Activity Forums Adobe After Effects Expressions a counter for exact value
  • a counter for exact value
    Posted by Kyaw Min on June 13, 2021 at 3:47 am
    I want to make a counter for exact value
    e.g in midi slider (thisComp.layer(“midi”).effect(“ch_0_pitch”)(“Slider”))
    includes notes’ values such as 45, 62, 48,45,45,82,95,72,45
    I want to count only note value 45 when slider pass it’s keyframe and create it’s increment counter.
    BTW my AE crash when I use while loop. so, It’s difficult to test with while loop.
    Kyaw Min replied 5 years, 3 months ago 2 Members · 2 Replies
  • Filip Vandueren
    June 14, 2021 at 2:40 pm
    I suppose you only want to count it when a keyframe on the slider equals 45, not when the slider happens to interpolate across 45 (e.g. from 44 -> 46if they’re not hold keyframes).
    sl = thisComp.layer("midi").effect("ch_0_pitch")("Slider");
    count=0;
    for (i=1; i<=sl.numKeys; i++) {
    if (sl.key(i).time>time) break
    if (sl.key(i).value==45) count++;
    count
  • Kyaw Min
    June 14, 2021 at 4:28 pm
    Thanks Filip,
    That is all I need .
    TBH , I don’t know how to use brake and continue. This is why I was stuck.
    I can count. but when criteria doesn’t meet , it shows the numbers blank or zero.
    Just blink the count number when a keyframe on the slider equals 45.
    I want to show the count number all the time just like you.
    Now happily finish one part.
