Activity Forums Maxon Cinema 4D A circular hole on the side of a cube
  • A circular hole on the side of a cube
    Posted by Hawkowski on May 8, 2006 at 5:05 pm
    Is there a way of openning a SMOOTH circular hole on one cide of a cube object WITHOUT using BOOLEAN operation between cube and a cylinder (or extruded circle etc)?
    ie. Is there a way of selecting cut region on the cube with spline object ?
    or any other method?
    Thx
    Adam Trachtenberg replied 20 years, 4 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    May 8, 2006 at 5:28 pm
    You can do this with Arndt’s Edge Extrude Pro plugin, available in the Dairy Store. Can also be done manually with a bit of work. What you would do is subdivide the cube side, project the circle spline onto it, and use snapping with “spline” enabled to created a circular group of faces. Then select the polys inside the circle/spline & delete.
  • James Leaburn
    May 9, 2006 at 2:14 pm
    You could just make a cube editable_ select two opposite sides_inner extrude_select the two extruded polygons_Use the bridge tool across these polygons( you may have to turm on the Xray option in the Display menu)_select all the sides without holes in and hold down the period key and left grag_make a few knife cuts close to the top and bottom of the hole to tighten up the edges.
    If in doubt scream and shout.
  • James Leaburn
    May 9, 2006 at 2:16 pm
    Sorry I forgot to say put the cube in a Hypernurbs.
  • Adam Trachtenberg
    May 10, 2006 at 7:49 pm
    Come to think of it, the easiest way to do this is to create an alpha and map it to the cube’s side. 🙂
