Activity Forums Adobe Premiere Pro A change in video quality when moved..
  • A change in video quality when moved..
    Posted by Jeremy Lee on November 10, 2006 at 2:51 pm
    I am noticing that if I adjust the videos placement on the y or x-axis that there is a slight reduction in the picture quality. It looks soft and not as sharp as the orignal footage. Is this normal or could it be that others have had this happen to them and there is something that I need to do in order to maintain the quality.
    JDL
    Tclark replied 19 years, 10 months ago 4 Members · 5 Replies
  • Vince Becquiot
    November 10, 2006 at 6:43 pm
    I have never noticed changes in quality when moving an axis, but there a slight change in quality when zooming in a picture, or footage regardless of its native resolution.
    Now, are we talking about quality in the preview window, or in an export, and is this uncompressed?
    I have, by the way learned not to trust what I see in the preview window, weird things happen there that are not actually in your export (Thankfully !)
    Vince
  • Jeremy Lee
    November 10, 2006 at 9:12 pm
    The problem happens when I move the video to a different location say like when using the video under a Digital Juice overlay. On my Avid I never had this happen, but if I just move the video to the left, right, up, or down the video looks soft like I shot it 30fps instead of a standard 60fps. I will have to export it to tape to see if it records out normal.
    JDL
  • Tcindie
    November 10, 2006 at 9:40 pm
    I would guess it’s likely just a preview window issue.. rendering it should bring it back to “normal”
  • Vince Becquiot
    November 11, 2006 at 1:50 am
    Does that softness go away in the preview window when the video is paused? If so, it’s that your preview is set to draft or auto quality instead of best quality.
    Vince
  • Tclark
    November 14, 2006 at 2:15 am
    Try adjusting a pixel at a time.
