Activity Forums Adobe Premiere Pro A challenge ? Turn black to white
  • A challenge ? Turn black to white
    Posted by Dennis on May 19, 2005 at 2:14 am
    I have a black costume that I want to convert to white.
    Can this be done in PP ?
    For example, here’s a perfect picture I found: blackwhite.jpg
    Can I use PP tools (or anything else) to convert the black side to look like the white side ?
    It doesn’t have to exactly match, just be white, as the costume I use is all black.
    A different alternative is to find a seamstress and have her sew a costume out of while fabric.
    But I wonder if it’s possible (or easier) to use some PP features to alter the color.
    Dennis
    Dennis replied 21 years, 4 months ago 3 Members · 3 Replies
  • Steven L. gotz
    May 19, 2005 at 5:16 am
    You could use a split screen created by a garbage matte, and put a white matte under the pic. So basically you key out the black and it shows the white.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Tim Kolb
    May 19, 2005 at 12:11 pm
    I might try to take the image and place it on V1 and put a copy of it above on V2. Take the image on V2 and apply Effects>Channel>Invert to it. Then place a Luminance key on it. If necessary, place the “Brightness and Contrast” Effect in between the “Invert” and “Luminance Key” in the list for image adjustments to tweak the key if it isn’t exactly right.
    If the image you showed was the image, it should be fine, if the background is black instead of white…things could get hairy.
    TimK
    Kolb Syverson Communications
    Creative Cow Host
    2004, 2005 NAB Post Production Conference Premiere Pro Technical Chair
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Dennis
    May 20, 2005 at 2:26 am
    thanks,
    the background will be dark, not white, but I guess I can use a green screen.. something to try. Or just sew another cloak.
    Dennis
