  • Charlie Austin
    October 19, 2013 at 4:07 pm
    Shot in the dark… might it have something to do with the text layer acting as an adjustment layer? If you delete the title, does the same thing happen?
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • James Ewart
    October 19, 2013 at 4:28 pm
    Thanks nice try – makes no difference.
    Having repeatedly trashed preferences and then trashed and reinstalled software (mid project…gulp) I have found a workaround.
    If I lift the still image jpeg from the primary storyline the problem does not occur.
    So can anybody explain that? It does not like still images on the primary storyline? Why I wonder?
    Thanks all
    James
  • Andy Neil
    October 19, 2013 at 4:38 pm
    What’s the format of the still? I wonder if its not really compatible but FCPX is trying to use it. CMYK or something?
    Also, Have you tried replacing the still with another shot and seeing if the same bug persists? And in your pics you didn’t show the video animation keyframes. Do you see the phyiscal keyframes moving/changing position when you go through the steps?
    Andy
    https://www.timesavertutorials.com
  • Jeremy Garchow
    October 19, 2013 at 4:41 pm
    What’s the spatial conform set to?
  • James Ewart
    October 19, 2013 at 5:19 pm
    I have no idea what spatial conform does I am afraid to say. Checked inspector and it’s set to “fit”
    It’s just a standard jpeg… should be okay no?
  • James Ewart
    October 19, 2013 at 5:26 pm
    Upon further investigation: With the still image (Jpeg) in Primary storyline selecting “fill” in spatial conform just zooms the image in a bit but by selecting “none” it replicates 100 % what happens when I disable and re-enable a connected clip.
    Does that give any clues?
  • James Ewart
    October 19, 2013 at 5:59 pm
    Have you tried this with a still image on primary storyline?
  • James Ewart
    October 20, 2013 at 12:43 pm
    Thanks for the reply.
    Nope I do not have this plugin.
  • James Ewart
    October 20, 2013 at 2:25 pm
    Have you tried with a simple jpeg in Primary Storyline with two keyframes, a move and a title on top?
  • Ronny Courtens
    October 20, 2013 at 2:29 pm
    Agreed. I have tried to reproduce this issue with a still on the Primary, with an adjustment layer over a still, with anything I can think of, and all of these things seem to work correctly. So this seems to be related to a specific issue on your system. Try the suggestions above and please keep us posted, this is interesting to know.
    – Ronny
Page 2 of 3
