Activity Forums VEGAS Pro A Bug ?? Please help
  • A Bug ?? Please help
    Posted by Or Tal on October 29, 2009 at 11:38 am
    “adjust size and quality for optimal playback”
    Is disabled, and I can’t check or uncheck it
    What is wrong ??
    (I tried all the options (draft full, auto, preview etc.) the button is disabled no mater what !
    thanks !
    Or Tal
    John Rofrano replied 16 years, 11 months ago 2 Members · 3 Replies
  • John Rofrano
    October 29, 2009 at 2:30 pm
    > “adjust size and quality for optimal playback” Is disabled, and I can’t check or uncheck it
    You must first enable Scale Video to Fit Preview Window and then Adjust Size and Quality for Optimal Playback will become enabled.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Or Tal
    October 29, 2009 at 5:59 pm
    OMG you are right !!!!! wow thanks!!
    How did you knew it ? and is there a logic behind this feature ?
    Or Tal
  • John Rofrano
    October 29, 2009 at 8:10 pm
    The logic that you can’t adjust the size for optimal quality unless you are scaling the size to begin with. Otherwise it just displays at a fixed size.
    ~jr
