Activity Forums Apple Final Cut Pro Legacy A Blu-Ray Solution for the Mac?
  • A Blu-Ray Solution for the Mac?
    Posted by Chris Babbitt on November 5, 2008 at 5:11 pm
    I’ve been looking into possible solutions for delivering my HD content, and after reading about all the problems with Encore on the Mac as well as other cost-prohibitive solutions, I came upon this article by Bruce Nazarian on Ken Stone’s web site:
    https://www.kenstone.net/fcp_homepage/taming_the_wild_blu_2.html
    It is a tutorial on how to create a Blu-Ray video disc with simple chapters using Toast 9.0.2 and the HD-BD plug-in. This looks like it might serve my needs for now. I haven’t seen this mentioned here. Is anybody doing this and how well does it work?
    Rafael Amador replied 17 years, 10 months ago 6 Members · 6 Replies
  • Sean Oneil
    November 5, 2008 at 10:00 pm
    My understanding is that Encore in CS4 works right.
    Sean
  • Walter Biscardi
    November 6, 2008 at 12:29 am
    [Sean ONeil] “My understanding is that Encore in CS4 works right.”
    Unless you have actually used it and have seen it work multiple times correctly, I would not believe anything Adobe says. That’s based on our experience with Encore CS3 and the Adobe Technical Team. All 12 months of our experience with that team.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Rafael Amador
    November 6, 2008 at 12:30 am
    The authoring capabilities of both programs are quite shorts. People uses Encore because there in not other cheap option available.
    About Toast, it could be fine if you could use it with the MPG-2 encoded with other applications. Not sure if is possible. So far I’ve only heard complains about his encoding quality.
    Till now I haven’t heard of the possibility to include titles in H264 with any of the two applications.
    Rfael
    http://www.nagavideo.com
  • William Carr
    November 6, 2008 at 4:44 am
    And then, for short duration content, there’s this intriguing possibility:
    https://www.dvda.org/content/view/2901/1/
  • Stuart Simpson
    November 6, 2008 at 10:17 am
    [Rafael Amador] “About Toast, it could be fine if you could use it with the MPG-2 encoded with other applications.”
    Not tried it with version 9 – but version 8 let you use MPEG2 files encoded using compressor.
    -Simmie
    5 MacPros – Kona 3 & Kona LH
    2 G5s – Kona LH
    xbox360, Wii, PSP, PS2
    https://www.speak.co.uk
  • Rafael Amador
    November 6, 2008 at 10:38 am
    Hi Stuart,
    You are right. I just sow in Toast 8 the “Reencoding: Never” option.
    And now I see in the Nazarian’s tutorial for Toast 9 a similar window with the “Reencoding” too. I guess there is a “Never Reencoding” option (Pity I can not click it in the web site to see if true).
    I see as well in the Toast 9 Compression window> Video Format: MPG-2. It seems that offers other options but, again, impossible to click in the page to display them.
    no point to look in the Toast web site. Almost no information at al.
    rafael
