Activity Forums Adobe After Effects Expressions Combining 2 Expressions
  • Combining 2 Expressions
    Posted by Patrick Schmid on February 6, 2023 at 11:40 pm
    im trying to combine those 2 Expressions…
    can anybody help me out? 🙂
    + add a option for Decimals?
    1st Expression for changing the font of the Text-Layer:
    var fontArray=[
    “BerninaSansOffc-Regular”,
    “DTFlowTextV1.011-Regular”
    v=Math.round(thisComp.layer(“Null 19”).effect(“Font CTRL”)(“Slider”))
    style.setFont(fontArray[v]);
    2nd Expression is a Counter with a Point Control because i need numbers greater then 1million:
    num = Math.round(effect(“Point Control”)(“Point”)[0]);
    function addCommas(x) {
    return x.toString().replace(/\B(?=(\d{3})+(?!\d))/g,”,”);
    addCommas(num)
    Filip Vandueren replied 3 years, 7 months ago 3 Members · 2 Replies
  • Dan Ebberts
    February 7, 2023 at 1:19 am
    Try this:
    num = Math.round(effect("Point Control")("Point")[0]);
    return x.toString().replace(/\B(?=(\d{3})+(?!\d))/g,",");
    txt = addCommas(num);
    var fontArray=[
    "BerninaSansOffc-Regular",
    "DTFlowTextV1.011-Regular"
    v=Math.round(thisComp.layer("Null 19").effect("Font CTRL")("Slider"));
    style.setFont(fontArray[v]).setText(txt);
  • Filip Vandueren
    February 7, 2023 at 2:18 pm
    Instead of the custom addCommas() method you can also use the built-in method:
    num.toLocaleString('en-us');
    and if you want decimals, don’t use Math.round() in the first line but:
    num = effect("Point Control")("Point")[0];
    txt = num.toLocaleString('en-us', {maximumFractionDigits: 2});
    This will limit it to max 2 decimal digits.
    if you always want 2 decimals (123.00) then:
    txt = num.toLocaleString('en-us', {minimumFractionDigits: 2, maximumFractionDigits: 2});
