Activity › Forums › Blackmagic Design › 9.5.3 Driver Eats My RAM – PPro CS6
Posted by Alan Peil on July 13, 2012 at 2:56 pmThe last couple of weeks, I had been having a mysterious and frustrating problem in PPro CS6 – I kept running out of RAM forcing me to restart PPro to clear the cache.
The frustrating part was that it wasn’t happening all the time. The only way I could reproduce the issue was to play a variety of sequences with a variety of media and keep an eye on the windows resource monitor. Eventually, the RAM usage would just keep slowly climbing until it hit 16GB (my total installed), then the timeline would start to choke.
Well, after 2 days of testing, I figured out that it was Desktop Video v.9.5.3 that was the culprit. Rolling back to 9.5.2 solved the issue.
Anyone else seeing this issue, or is it some conflict with 9.5.3 and my machine?
Bo Higbee replied 14 years, 1 month ago 9 Members · 25 Replies -
Andreas Wojtaschek
July 14, 2012 at 5:14 pmI can confirm this.
Since 9.5.3 I have massive problems with CS6.
Especially with AVC Intra footage.Regards
Andreas
Entertainment Producer IHK
mindandvision -
Joshua Helling
July 16, 2012 at 10:56 pmHey guys,
This sounds odd, not sure why the codec type would cause this sort of thing since Premiere Pro itself handles all the decode, but it certainly seems like you guys are experiencing it.
Can you give me your system details here and more specifics on the format you’re using and how you’ve configured your preset (rather which you are using?).
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc. -
Alan Peil
July 17, 2012 at 2:57 pmHey Joshua,
Thanks for looking into this. Here’s my system specs:
CPU – Intel I7 3.2ghz
RAM – 16gb
Windows 7 64 bit
Nvidia GeForce GTX 285
Decklink StudioI’ve seem this RAM issue happen with all sorts of sequence presets, but I first noticed it when playing out a 10 minute long “D1/DV NTSC (0.9091) 30fps drop frame” sequence (yes, we still work in SD at my TV station, AND still roll out to beta…I know, it’s a sad sad thing).
Let me know if you need any other info.
Alan
Joshua Helling
July 17, 2012 at 6:00 pmCool Alan,
Thanks for that information. I’ll have someone test this now. Are you using native DV footage? I’ll get this setup in our lab today to look at.
Sincerely,
Joshua
Director of Support
David Porto rodríguez
July 17, 2012 at 6:28 pmHi,
Same issue here, i tried with 9.5.3 and with 9.6, both eating RAM, i had to downgrade to 9.5.2.
Another issue i’m experimenting is that there is a delay from the desktop viewer to the video output of 5-6 frames, which is a pain in the ass to audio sync editing. This delay is there in every version. No delay with FCPX or FCP7.
I’m using a MacPro 4,1 – 16GB RAM – RAID 0 6TB and Decklink SDI.
Joshua Helling
July 17, 2012 at 9:59 pmWhere is your audio coming from? Are you connected to the Decklink or are you using the desktop speakers?
If you are go to Premeire -> Preferences -> Audio Hardware. Make sure that setting is set for Blackmagic Audio.
This will make sure that the audio and video are both coming from the Decklink board. This will guarantee they are in sync at the board (there might be a few frames delay from the program monitor, but this is normal).
If you use different devices to play audio and video we cannot guarantee A/V sync.
This of course means that you have to have a monitor that can either monitor audio from SDI or you will have to get a de-embedder to monitor the audio via Analog or AES.
Sincerely,
Joshua
Director of Support
July 17, 2012 at 10:08 pmHi Joshua,
The audio is coming out the Blackmagic and it is indeed in sync with the video on the external monitor, the problem is it’s delayed 5-6 frames from the premiere viewer, so you say this is a normal behavior? This won’t be corrected? Is it a Adobe problem? Because in FCPX and FCP7 this doesn’t happen.
David
Carl Schuurbiers
July 18, 2012 at 4:38 pmHi David, Joshua,
Please allow me to hijack this thread a little further… 😉
I have a Decklink SDI card and a similar problem. About 5 frames delay between program monitor and the external monitor. When I send audio through the Decklink SDI it is indeed sync with the video on the external monitor (as David reports) but I can’t look at the program monitor on the computer screen, because it is horribly out of sync.As I posted earlier, we need the following:
1. speed up displaying of frames from Premiere to the output card->external monitor. Driver optimization? Users with Kona3 cards report both monitors and audio in sync, and with final cut 7, there is also less lag, so it must be possible to have a lot less lag at least. In the current situation it is just too much.
2. I can understand that some latency in the path to the external monitor may be unavoidable. Also external monitors themselves have some lag. To compensate we need to be able to set a delay for the program monitor so that what it displays is sync with what can be seen on the external monitor. Final Cut 7 has such a setting.(under system settings -> play back control -> frame offset.)
3. Another delay, but for the audio only. This way, people who are using a different interface/path for the audio can adjust the audio delay to make sure their audio is perfectly sync to the picture. Also “sensitive” people like me 😉 can trim audio in sub-frame units (in miliseconds for instance) to make audio sync even more precise.
My conf.: Mac Pro (mid 2010) 8-core, 24GB RAM, Quadro 4000, Decklink SDI with 9.5.2 drivers. Pr6.0.1
Cheers,
Carl.
Joshua Helling
July 18, 2012 at 5:47 pmActually FCP7 (at least) behaves similarly, but I believe it’s only like 3 frames or so off. This is a result of the buffering. I’m not sure why the offset is so far, i’ll check to see with product management to see if this is normal, or if it is something that can be improved.
the good news is that we have indeed reproduced the memory issue and are writing it up as a bug today and the engineers are already looking at it.
Sincerely,
Joshua
Director of Support
