9.0.2 Doesn’t play well with FCP 7
I have CatDV 9.0.2 setup with tons of clips catalogued, lots of DVCPRO HD 729 59.94 and am having lots of issues getting it into fcp 7. I’m being very careful not to mix formats in sequences as well as when I export FCP7 XML files. So far I have had no success with clips working properly in a timeline in FCP, the in and out points are always off, clips will show up multiple times in a sequence in fcp even though it only appears once in the catdv sequence, even the format of the clip and sequence settings are always off.
Am I the only one with this issue? Is it a problem with the format?
Also I am unable to drag and drop sequences or subclips into fcp. I can only drag and drop original clips and in and out points are not recognized.
8 Core Intel Mac
OSX 10.6.8
FCP 7.0.3
CATDV 9.0.2
