Activity Forums DaVinci Resolve 9.0.1 window tracking issue
  • 9.0.1 window tracking issue
    Posted by Prathvish Hegde on September 27, 2012 at 11:32 am
    hi,
    have any one tried tracking window on 9.0.1 ????
    now i cant track any shot automatically either i have to use a stationary window or manually track as i do on davinci 2kplus (is it the worlds best tracker we are talking about???? anymore!!!)
    prathvish hegde
    colorist
    Margus Voll replied 13 years, 11 months ago 11 Members · 20 Replies
  • 20 Replies
  • Ola Haldor voll
    September 27, 2012 at 11:57 am
    Something has indeed changed.
    I tracked something I tracked yesterday. I struggled a bit to get it right now, compared to yesterday when this was a one-button-operation.
    Here’s a screenshot for comparison. Nothing was adjusted. I simply hit the “Track forward” button on the already tracked window.
    I’m having a hard time tracking other, really basic things, too.
  • Margus Voll
    September 27, 2012 at 12:33 pm
    hmm weird 🙁
    Margus
    https://iconstudios.eu
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Andrew Smith
    September 27, 2012 at 12:38 pm
    Yeah Tracking not working well for me – having to manually keyframe a shot i was able to just auto track in v9beta3 or V8.
  • Rohit Gupta
    September 27, 2012 at 1:14 pm
    Hi,
    I just checked this here, and I didn’t see any problems immediately.
    Can you provide some more details:
    1. Does it happen on clips of a specific resolution? (Does it happen with HD files, HD timeline resolution)
    2. Can you confirm the same project works ok in 9.0, but not in 9.0.1?
    Rohit
  • Ola Haldor voll
    September 27, 2012 at 1:22 pm
    1. HD (1080p)
    2. I started the project in 9.0 – updated early this morning and the tracker seems to be a bit less sticky compared to 9.0. Not that it’s doing an insanely bad job, just not completely like it was in 9.0
  • Rohit Gupta
    September 27, 2012 at 1:41 pm
    Hmmm there have been no changes in that area. Are you able to re-install the 9.0 version to check against the same project and same window position preferably.
    The DB is same version so you should be able to go back and forth.
  • Prathvish Hegde
    September 27, 2012 at 2:55 pm
    i tried on a 9.0 project which i had to make few changes and a few new replaced shots the shot didnt have any windows before but when i added a window after upgrading to 9.0.1 i found that the window is not tracking correctly (way off for me) this shot was a simple shot to track and i tried by even keying and tracking the portion (which i do sometimes for a better track) but no luck.
    mine is a linux resolve(9.01) and i have been on the machine since version 7 with the new panels i have never have seen this happen before.
    prathvish hegde
    colorist
  • Dwaine Maggart
    September 27, 2012 at 3:22 pm
    In Project Settings, Image Scaling, what Input Scaling Preset do you have selected?
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Prathvish Hegde
    September 27, 2012 at 4:29 pm
    hi,
    project is 1920*1080psf ,square pixel ,input scaling – center crop with no resizing
    output scaling – center crop with no resizing
    monitor out -1920*1080sf
    after playing around for a while i have noticed this problem is present in only sessions upgraded from previous version 9.0 and not on new projects created on 9.01 is it a bug????
    prathvish hegde
    colorist
  • Sascha Haber
    September 27, 2012 at 4:45 pm
    Well, its certainly a bug, but i have made a new session and its there too.
    When changing the input sizing to another scale method it seems to work.
    Center crop sometimes looks like the tracking image is three times bigger than the timeline.
    I can see the movement follow the actors face, but extrapolated.
    A slice of color…
    Resolve 9.01 OSX 10.8.2
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
