Activity › Forums › DaVinci Resolve › 8.2 Alpha channel
  • 8.2 Alpha channel
    Posted by Andrew Sableton on August 23, 2012 at 7:34 pm
    I have a ProResHQ FCP7 sequence with ProResHQ media except for some FX material that is in animation codec with alpha channels. Should I bake these animation codec clips as ProResHQ and then somehow extract a matte from them to import into a node in DAVINCI? Will this then work in a round trip?
    I’m a little confused as to how to get this to work…..
    S
    Eric Johnson replied 14 years, 1 month ago 4 Members · 5 Replies
  • Andrew Sableton
    August 23, 2012 at 7:36 pm
    Also Davinci seems to refuse to see the animation codec QTs at all – I look in the folders where they should be through the DAVINCI browse page and these clips do not appear, although they are in the OSX finder….
  • Joseph Owens
    August 23, 2012 at 9:07 pm
    So, a couple of things.
    First of all, if you go looking at the https://www.blackmagicdesign.com/media/2588311/davinci_resolve_8.2_supported_codec_list.pdf
    you won’t find the Animation codec. It won’t appear on a lot of lists.
    Its a bit long in the tooth as a “lossless” codec, its only adavantage now being that it is one of the few that can carry an alpha channel, but then there’s ProRes 444.
    Resolve 9 can use alpha channels for matte purposes, but not 8.2. You will have to extract the alpha channel somehow and export that (exact length of the original clip) as a recognized codec and attach it to the source clip as an external matte. You cannot export an alpha out of Resolve.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Andrew Sableton
    August 23, 2012 at 9:20 pm
    Ok thanks JPO – what would your process with FCP be to ‘extract’ the alpha?
    S
  • Sascha Haber
    August 24, 2012 at 6:15 am
    Please just upgrade, you will love it and need to learn a cumbersome workaround .
    A slice of color…
    DaVinci 9b3 OSX 10.8
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Eric Johnson
    August 24, 2012 at 8:32 pm
    For a luma matte, you can load your clips in the viewer, change your view from RGB to ALPHA. You should see a B+W of what your alpha should be… and export.
    I’m sure there are other ways. That’s the way I know of.
