Activity › Forums › Adobe After Effects › 8000×1000
8000×1000
Posted by Lee Griggs on December 10, 2008 at 10:03 pmHello, I have a client that wants me to render out to 8000×1000 pixels. I thought the maximum AE could handle was 4000? Has this changed at all?
cheers,
leeJimmy Brunger replied 17 years, 9 months ago 3 Members · 2 Replies -
Walter Soyka
December 11, 2008 at 12:22 amHi Lee,
The theoretical maximum comp size is 30,000 by 30,000 pixels. We frequently do comps larger than 8,000 by 1,000 for multi-displays systems. The larger your comp is, the more RAM each frame will use, and the shorter your previews will be. You can also definitely expect some lengthy render times.
Also, you might want to find out how you are expected to ultimately deliver the animation, because different playback systems will have different requirements.
Walter Soyka, Principal
Keen Live, Inc.
Presentation, Motion Graphics & Widescreen Design
RenderBreak: A Blog on Innovation in Production -
Jimmy Brunger
December 11, 2008 at 12:23 amWe work at 7000 across quite alot…it works fine but everything takes AGES! you hit a RAM limit somewhere not far above that size, but I guess if AE went 64-bit you might have more headroom..
AE7 Pro – Nucleo – Mocha v1.2.3 – PS CS3 – FCP 5.1.4
MacPro Quad 3GHz / ATI 1900XT / 8GB RAM / OSX 10.4.11
30″ ACD / Decklink SP / SONY PVM-20M4E/ Wacom Intuos 3 A4 / XServe / United Digital RAID
Production Studio CS2 – Combustion 3 – Mocha v1.0.1
Win XP Pro 32 / Intel Core2Quad Q6600 / 2GB RAM / NVidia Quadro570 / DeckLink Pro / Roland DS-5s / Sony BVM-20G1E / 2 x Dell 2007FP / Wacom Intuos 3 A4 / 320GB boot/800GB RAID-0
