Activity Forums Apple Final Cut Pro Legacy 720/50p support?
  • 720/50p support?
    Posted by Galen Yeo on July 23, 2007 at 11:13 am
    I was told that FCP can import and playback 720/50p in a 25p sequence but I don’t see the specs supporting this on the apple webpage. Can someone confirm this? Thanks in advance.
    Rafael Amador replied 19 years, 1 month ago 3 Members · 6 Replies
  • Uli Plank
    July 23, 2007 at 2:07 pm
    It can be hacked into doing this. Check: http://www.aulich-adamski.de (the site is in German, but the explanation is in English).
    Regards,
    Uli
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
  • Rafael Amador
    July 23, 2007 at 2:48 pm
    Hi Uli,
    We’ve been missing you for a few months in the Cow. I guess you have been busy with your new responsabilities (IMF).
    I wanted to ask you long ago for a good set-up for short GOPs MPG2. When you got time.
    Thanks in advance,
    rafael
  • Uli Plank
    July 23, 2007 at 3:18 pm
    Hi Rafael,
    nice to hear from you. I was buried deeply in Apple’s Color…
    What do you mean by short GOP ? Betacam SX?
    Regards,
    Ulinho
  • Rafael Amador
    July 24, 2007 at 2:16 am
    Hi Uli,
    I’m trying to improve my DVDs and I’m experimenting with short GOPs. Now it seems that the most of the DVD players can cope with a higher data-rate and the difference in quality is noticiable. But I’m not sureabout howmuch to push the Average and the Maximum Bit-rate. I remember that you were very aware of this technology.
    Cheers,
    rafael
  • Uli Plank
    July 24, 2007 at 5:26 am
    Well, short GOPs are a trade-off between coping with very fast changes in the image (like hand-drawn animation) and the need of a higher data rate.
    The usual half second data rate is kind of a “sweet spot” for typical footage from a camera.
    Don’t set your data rate too high for DVD-R, many players start choking beyond 8 or 8.5 mbps. For replicated disks you can go all the way to 10.08
  • Rafael Amador
    July 24, 2007 at 11:50 am
    Thanks a lot for the info Ul.
    Cheers,
    Rafael
