Activity Forums Panasonic Cameras 720/25P vs 720/25PN ?
  • Nigel
    May 1, 2006 at 12:40 pm
    Maybe better if I shoot PN to both P2 and Firestore so there are no complications?
  • Shane Ross
    May 1, 2006 at 2:39 pm
    As I said, you cannot shoot PN to the firestore. It only shoots 24P at 59.94fps…24p with pulldown.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Nigel
    May 1, 2006 at 3:12 pm
    Sorry, I meant to say shoot 720P/25P to both P2 card and Firestore; this would work right?
  • Gary Adcock
    May 1, 2006 at 3:36 pm
    [Marcus van Bavel] “720p25 is stored in a 1080i50 stream so every other frame is redundant.”
    Not correct marcus
    720p25 is stored in a 720p50 video stream, 1080psf25 is laid into the 1080i50 using a 2:2:2:2 patter where every 1080 frame is separated into 2 fields
    ga
    Studio37
    HD & Film Consultation
    Chicago, IL
    gary@studio37.com
  • Gary Adcock
    May 1, 2006 at 3:40 pm
    [iMan] “Sorry, I meant to say shoot 720P/25P to both P2 card and Firestore; this would work right?”
    iMAN
    there is NO 25PN mode on the firestore, only 25p – All attached FW devices accept the video as if they were being recorded to tape.
    FCP does NOT currently support 720p25 or 720p50 properly
    Studio37
    Chicago, IL
    gary@studio37.com
  • Marcus Van bavel
    May 1, 2006 at 6:02 pm
    [gary adcock] “720p25 is stored in a 720p50 video stream, 1080psf25 is laid into the 1080i50 using a 2:2:2:2 patter where every 1080 frame is separated into 2 fields
    ga”
    Gary what is the SMPTE spec for 720p50? SMPTE 370M describes 1080i60, 720p60 and 1080i50, but no
    720p50. Also the frames for 720/25pn as recorded by the HVX200 take up exactly half the same amount of space as a 1080i50 frame, and they take up more space per frame than 720/30pn or 720/24pn. (288,000 bytes vs 240,000 for 720/30pn). Did you know that?
  • Barry Green
    May 1, 2006 at 6:06 pm
    I was curious about the statement about 1080/50i as well (that 720/25p is transported within the 720/50i stream). That seems quite curious, but — Marcus has written his own DVCPRO-HD codec and probably knows more about it than all the rest of us combined.
    I would expect that a 720/50p frame would take up more space than a frame from a 720/60p stream, since 100 megabits / 50 fps = 2 megabits per frame, vs. 100 megabits / 60 fps = 1.67 megabits per frame. But does that necessarily mean that it’s carried in a 1080 stream? Or that they’ve just updated the standard for the new 720/50p stream?
    Marcus, I sent you contact info for someone from Panasonic EU — hopefully he can help you to understand everything they changed in the new 720/50p and 720/25p modes.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Mike Schrengohst
    May 1, 2006 at 8:45 pm
    I have Raylight and will upgrade in short order.
    I will have a bunch of 720/25p footage coming in.
    I will report back…..
    Mike Schrengohst
    http://www.MotionZoneHD.com
  • Gary Adcock
    May 2, 2006 at 1:01 am
    [Marcus van Bavel] < "SMPTE 370M describes 1080i60, 720p60 and 1080i50, but no 720p50. " SMPTE 296 has the listing for the 1280×720 progressive HD recording format and I do not believe there is an included standard for 720p50 listed in the current doc’s online. https://www.smpte.org/smpte_store/standards/index.cfm?scope=0&stdtype=smpte&CurrentPage=12
    [Marcus van Bavel] ” Also the frames for 720/25pn as recorded by the HVX200 take up exactly half the same amount of space as a 1080i50 frame, and they take up more space per frame than 720/30pn or 720/24pn. (288,000 bytes vs 240,000 for 720/30pn). Did you know that?”
    Marcus that would be correct. Recording in the PN modes always result in less data being captured because there are not any additional frames being added. The 24PN modes respond the same, being 1/2 the size on P2 that the 1080 formats require.
    As for the difference in actual file size, I do not have a current version of the HVX200E (25p) camera to test your numbers but I think that is the difference within the color space and number of audio channels and their compression (but I could be wrong)
    Studio37
    Chicago, IL
    gary@studio37.com
  • Marcus Van bavel
    May 2, 2006 at 4:08 am
    [gary adcock] “Marcus that would be correct. Recording in the PN modes always result in less data being captured because there are not any additional frames being added”
    I’m comparing one pn mode to another pn mode, (25pn to 24pn for example) and I’m talking about the number of bytes per frame. It’s different for the 50Hz camera. There are 240,000 bytes of good data but sitting inside a block of 288,000. This is why Apple, Avid and Canopus were all caught by surprise and can’t presently read the 720/25pn format. It does work with Raylight, though, and the new version of DVFilm Maker (2.3) which will be released later this week.
