Activity Forums DaVinci Resolve 7.0.3 crashing
  • 7.0.3 crashing
    Posted by Michael Stirling on December 8, 2010 at 5:18 pm
    Hi
    I’ve just upgraded to 7.0.3 and I’m finding it crashes much more than the last build.
    It’s happened more than 10 times today on a simple project (20 shots of 1080 pro res).
    Also, resolve no longer seems to create back up projects
    Anyone else finding these problems,
    thanks,
    Mike
    Rohit Gupta replied 15 years, 8 months ago 4 Members · 3 Replies
  • Chris Hall
    December 9, 2010 at 1:46 am
    No Crashing here, working on Uncompressed 10bit 4:2:2 23.98fps feature for past week and haven’t had a problem.
    Autosave works fine for me. You may already know this, but make sure to check “To backup project” if you want autosave to save it to the “Auto-backup List” (also, you might need to hit refresh to see it there if you don’t). Just checking autosave “on” literally saves the project to the “current project” (not on the auto-backup list).
    Chris Hall
    Colorist – Basher Films
    Pasadena, CA
  • Martin B. wehding
    December 9, 2010 at 8:48 pm
    yes. We had the same issues. It crashed everytime it tried to create a autobackup.
    If it was set to backup every 10 min. it crashed every 10 min. if it was set to BU every 1 hour it crashed every 1 h.
    We reported the problem to Blackmagic. They suggested to switch it to autosave instead of BU. That solved the problem.
    All the best
    Martin
  • Rohit Gupta
    December 10, 2010 at 5:20 am
    Hi Martin,
    Could you please capture logs when the crash happens, and send it to our support email address – davincihelp (at) blackmagic-design.com?
    The logs can be captured using the CaptureLogs app in /Library/Application Support/Blackmagic Design/DaVinci Resolve/ folder.
    Rohit
