Activity Forums Blackmagic Design 6.6 and Decklink Output using XPx64
  • 6.6 and Decklink Output using XPx64
    Posted by Ian Mcguffie on October 29, 2007 at 3:34 am
    Anyone have any experience using the new Decklink driver(6.6) on XPx64?
    Have just installed 6.6 and now find that outputting video via the Blackmagic Deck Control utility, to Digibetacam-PAL, I have a 12 frame hold of the first frame (the clip is delayed 12 frames). The “Prefs-Put Offset” only gives me +-5 frames to compensate so can’t get this back correct.
    “Get Clip” works fine.
    I have been using 5.6.1 with no problems.
    Also I can’t type in numeric values into the timecode IN/OUT boxes.
    Also any one have any experience with 6.6/XPx64/Vegas8a ???
    Matt Wright replied 18 years, 10 months ago 2 Members · 2 Replies
  • Matt Wright
    October 31, 2007 at 9:05 am
    Hi Quokka
    I see you are trying all the forums as well, it sounds like you have a smilar set-up to me XP64, Vegas 8.0 / 8.0a and a Decklink Device.
    I have had no luck at all with this set-up, although I did get an email from Decklink, saying that the 64bit 6.6 drivers SHOULD work with Vegas 8.0 (build 144), but it may not work with 8.0a.
    I have tried this myself, but do not still have any luck with it.
    Let me know if you try it, and it works for you.
    Cheers
    Matt
  • Matt Wright
    November 9, 2007 at 7:48 pm
    Hi There.
    I have just downloaded and tried BlackMagic Drivers versions 64 bit 6.6.1, in XP64, and just as I suspected it did not work, with the same probklem as before, the device just does not show up in Vegas.
    BUT.
    After looking around I noticed that in the Vegas8 directory, in the “Video Hardware Drivers” directory, that there was no refernce to Decklink at all.
    I compared this to a system that worked, running XP32 and the 32bit drivers and there was a file there called “DeckLink Vegas.dll”
    So just a complete lucky try, I copied this file onto the 64bit system, and hey Presto, it only worked, I can now get the option to select the Multibridge as a preview device and, to my complete surprise I even get an output which seems to work. Although not 100%, but it works.
    So my conclusion is that the 64bit drivers supplied by Decklink just do not install correctly, or they do not put this dll into the correct place.
    I will have a really good look at this Monday, but at least we may be able to get an output from the Decklink now in 64bit systems.
    Quoka if you PM me, I can send you the dll which sort of worked, basically the thing which didn’t work was if I selected an HDV 1440×1080 50i Project in Vegas it would only preview in SD mode, but if I selected a 1920×1080 50i project it would output perfectly in HD.
    This is fantastic, at least I feel I am getting somewhere, I brought this MultiBridge Box over a year ago, and have been fighting ever since with Vegas to get it to work.
    What I can’t understand is that I have been in communication with BlackMagic over this issue for a quite a few weeks now, and it would seem a simple problem, but they haven’t managed to come up with any suggestions.
    Matt Wright
