Activity › Forums › Broadcasting › 625/50 do they mean PAL?
  • 625/50 do they mean PAL?
    Posted by Mark Rivers on May 4, 2009 at 11:33 pm
    Hi,
    I need to deliver an Standard Definition 16:9 digibeta tape to a company in France.
    They sent me a Tech Spec Packet which states:
    “Video signals shall be produced in 4.2.2 format, 10 bits 625/50”
    I’m assuming this refers to the PAL format.
    However in the same packet it also states:
    “The signal shall never have been PAL or SECAM coded”
    What exactly do they mean when they say “coded?”
    I plan to layoff to 16:9 (720×486 anamorphic widescreen) NTSC Digibeta and then make a PAL conversion. That’s what they want right?
    Thanks everyone.
    I love this site.
    Maurice Jansen replied 17 years, 5 months ago 3 Members · 2 Replies
  • Asmund Voll tesdal
    May 5, 2009 at 9:30 am
    In this context I believe they are referring to PAL as in composite. You’re correct in that 625/50 is “PAL” frame size/rate.
  • Maurice Jansen
    May 5, 2009 at 5:16 pm
    well
    stricktly speaking pal is of coarse a composite standard whith 625/50 they mean digital component normaly SDI in 50HZ with indeed the resolution of 720×576. in your country they will call it 525/60 with a resolution of 720×480
    what they are trying to say is that the material may not be framerate/norm converted in the composite domain.
    greet
    Maurice
