Activity Forums Blackmagic Design 5.7.2 hardware down convert
  • 5.7.2 hardware down convert
    Posted by Chris Paul on October 20, 2006 at 8:38 pm
    After upgradeing to the 5.7.2 my miltibridge extreme now displays DVCproHD correctly but now it no longer displays HD and down converted SD at the same time. The hardware down conversion to the analog output seems to be at fault.
    Chris Paul
    POV
    Luke Maslen replied 19 years, 10 months ago 2 Members · 3 Replies
  • Luke Maslen
    October 23, 2006 at 4:16 am
    Hi Chris,
    I’m glad the update has solved that problem.
    Multibridge Extreme has only ever had hardware down conversion of HD1080 material. If you want to down convert HD720, you will need to use software down conversion. Does this explain what you are seeing?
    Regards,
    Luke Maslen
    Blackmagic Design
  • Chris Paul
    October 23, 2006 at 6:56 pm
    No, I knew that it only did simultanious HD and SD dispplay via hardwar with 1080i material. BTW, I finally got both that and the DVCproHD scaling to work at the same time by cycling the power on the MBE twice. I guess it is a good idea to cycle the power when other solutions do not work.
    Chris Paul
    POV
  • Luke Maslen
    October 24, 2006 at 5:11 am
    Hi Chris,
    I’m glad the problem has gone away but don’t understand what was happening. If it comes up again, please let us know.
    Regards,
    Luke Maslen
    Blackmagic Design
