Activity › Forums › Blackmagic Design › 5.21 not installing plugins and presets
  • 5.21 not installing plugins and presets
    Posted by Shane Chadder on October 14, 2005 at 12:55 am
    Hi
    Others have complained about this and i found the same problem. I have to manually copy the presets and plugins over for Decklink to work from within Premiere.
    Shane Chadder replied 20 years, 11 months ago 3 Members · 5 Replies
  • Matt Dowling
    October 14, 2005 at 1:12 am
    Hi Shane,
    Is there any chance that you have Premiere Pro 1.0 installed on your machine as well as Premiere Pro 1.5?
    Cheers,
    Regards,
    Matt
    Blackmagic Design
  • Shane Chadder
    October 14, 2005 at 1:24 am
    No
    But I’ll do a search and see if they are being installed in some other apps. plugins.
  • Shane Chadder
    October 14, 2005 at 4:09 am
    No Matt, I give up.
    This box has run fine for a couple of months with earlier versions.
    I reinstalled Pro, and its 1.51 update, nuked any registry entries related to premiere 6.0 (uninstalled long ago), but neither 5.2 nor 5.21 will install their presets and plugins. I had to move the files manually to their respective directories. 5.2 installed fine on one of our new systems a couple of weeks ago. Who knows.
    Shane
  • Oscar G.
    October 14, 2005 at 11:11 am
    Hy
    I don’t remember if 5.1 does the same thing, but the installer copy presets into the settings folder of ppro…. but not in your language folder.
    If it’s this issue, just copy/move the black magic settings folder in your country path! (FR, Uk ,Ge, JA…)
    settings path of ppro :
    C:\Program Files\Adobe\Premiere Pro 1.5\Settings
    you will found a black magic folder here, just after instalation
    hope this helps
    Regards
    Oscar
  • Shane Chadder
    October 15, 2005 at 5:16 pm
    Thanks Oscar but it isn’t installing the presets or plugins at all. I have to move them from the Black Magic directory into the repective folders in Preiere’s directory. I have it working.
