Activity Forums Audio 5.1>2.0 “Fold & Bump” with Frame Rate Conversion
  • 5.1>2.0 “Fold & Bump” with Frame Rate Conversion
    Posted by Bob Jones on July 26, 2009 at 6:46 pm
    Hi There,
    First time post, and I’m looking for a little help. I’m working on a project for a client, and they’ve asked me to perform a process that I’m not terribly familair with. They have supplied me with a 5.1 mix that is timed to 24 fps from film. They want me to convert this to a 2.0 mix that is timed to 25 fps for PAL release. I’ve told the client that normally this would be done by an audio professional (which I make no claim to be), but they are in a pinch and just need something “quick, cheap, and dirty.” I’ve told them that with my toolset, I should be able to perform this for them in some automated fashion, and I’d like to do this in 1-2 steps if possible. Here is what I’m working with:
    Source
    6 Discreet WAV files (L,C,R,Ls,Rs,LFE)
    Tools Available
    Pro Tools LE
    Final Cut Studio Suite
    Adobe CS3 Suite
    Rhozet Carbon Coder
    Inlet Fathom
    Telestream Episode
    Quicktime Pro
    Steps to Perform
    1 – “Fold down” 5.1 audio > 2.0 audio
    2 – Increase overall volume level by + 3db
    3 – Convert from 24 fps to 25 fps (increase speed by 4.1% while maintaining pitch)
    4 – Output should be a single stereo WAV file
    Any help or advice would be greatly appreciated!
    Also, if I am thinking about this entirely wrong or am way off base here, please feel free to thoroughly correct me. I will not take it as an insult and will greatly appreciate your feedback!
    Peter Groom replied 17 years, 1 month ago 2 Members · 1 Reply
  • Peter Groom
    July 27, 2009 at 8:40 am
    HI
    as far as your discreets go. Does your discreet tracks have divergence mixed in to the lefts rights from the centre. If yes then the % will affect how much you put this centre into the LR.
    But
    Put Left – left
    right – right
    Centre to left and right (note above)
    Ls & Rs to L & R but decrease this level by @ -6 db. (YOU NEED TO FIND OUT IF THE REARS HAVE ANY PHASE REVERSE ON THEM. IF THEY HAVE THEY WILL PHASE CANCEL THE FRONTS WHICH IS DISASTER.
    remove the .1 sub.
    MONITORING
    monitor the whole thing back in a stereo foldwown. Or listen to the stereo back later and adjust. Youre listening for any strange artifacts phase wise. Also be willing to re visit the levels of any elements to adjust.
    Im not sure on your pull up for 25 PAL. id post this question to the Digidesign DUC regarding that as I dont know what ptle has in this area.
    Peter
