Activity › Forums › Apple Final Cut Pro Legacy › 500GB+ portable bus-powered FW800 drive?
  • Ed Dooley
    February 18, 2008 at 7:05 pm
    Actually Walter, my math may be off, but there is a difference in reliability between a single drive and a 2 drive RAID0. Twice as many drives, each with a possibility of failure, and the odds are greater that the raid will fail before a single drive. Or maybe this is one of those quantam things I slept through in math. 🙂
    Ed
    [walter biscardi] “Um, you’re talking about a single drive so by default there’s no “protection” for a single drive.
    Hence there is no difference between a single drive and the RAID 0 of the G-RAID mini.
    There’s nothing wrong with RAID 0 so long as you back up your material, just as if you’re going to get this single drive, you need to back up that material if you want to protect it.”
  • Jimmy Brunger
    February 18, 2008 at 9:33 pm
    Yeah, that’s what I meant Ed..but now i’m not sure my maths of probability are right either!?
    I am kind of using this drive as my sole storage for the moment, so I guess a RAID-1 might be a good idea. Planning on getting a big CalDigit or similar fairly soon, but I need to do some work off my laptop for now and need a temp solution. I will look at these RAID-1 solutions.
    My only big problem now remains that I can’t get any versions of Premiere Pro to work with a Power PC mac running Leopard! And Final Cut don’t do a trial version!! I needed to offline on Premiere ideally, but now I’ll settle for any cheap/free trial NLE I can run that will spit out an EDL!
    Any ideas guys?
    *Production Studio Premium CS2 / *Combustion 3 / Mocha v1.0.1 / Elastic Reality
    Win XP Pro 32 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5s / Sony BVM-20G1E / 2 x Dell 2007FP / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB/80GB/600GB RAID-0
