Activity Forums Adobe After Effects 5000 x 3400 image buffer error
  • 5000 x 3400 image buffer error
    Posted by Rich Tencza on March 28, 2006 at 3:27 pm
    Hi folks.
    I am rendering a comp with many high rez stills.
    “The Kid Stays in the Picture” type of style with the still broken into many layers
    and on different Z planes with moves, cc, blurs and rotations.
    I keep getting an AE error at a certain point saying.
    After Effects Error: Could not create 5000 x 3400 image buffer. (7::39)
    What can I do to get past this problem spot? Any help would be greatly appreciated!!
    Rich
    AE 7.0 / QUad 2.5 GHz G5 /4 GB RAM
    Steve Roberts replied 20 years, 5 months ago 2 Members · 1 Reply
  • Steve Roberts
    March 28, 2006 at 3:54 pm
    Have you tried the secret prefs? They allow you to purge your memory while rendering. Hold down the shift key while accessing the prefs (keep holding down the shift key until the dialog box appears) then look for the secret prefs. Try setting it to purge every 5-15 frames during Make Movie.
    It might slow down your render, as AE will have to recreate cached frames, but it may help solve your problem.
    Keep your Task Manager (or whetever it’s called on my switched-off Mac) open to monitor RAM usage.
