Activity Forums Maxon Cinema 4D 500 fps
  • 500 fps
    Posted by Doug Kerrigan on May 27, 2015 at 1:34 am
    Hey guys, I had a quick question about fps. I realize there are two ways to change fps (Project Settings/Render Settings), but I can’t seem to get over 500 fps. I was hoping for something around 1000fps (phantom speed). I’ve baked all of my meshes already so I’m not getting a MoDynamics with my Rigid Body tag anymore, I was trying to change the Time Scale. Is there another way to slow down my project?
    Thanks in advance,
    D
    Cassius Marques replied 11 years, 3 months ago 3 Members · 4 Replies
  • Cassius Marques
    May 27, 2015 at 7:42 pm
    Can you explain better why do you need to do this? I mean, even if you could i’m doubting your computer will be able to preview that fast…so what exactly do you want to achieve?
    Where and how do you intend to preview your final file?
  • Ryan Paterson
    You could render twice as many frames and then interpret the footage in After Effects to play back slower
  • Doug Kerrigan
    May 27, 2015 at 7:52 pm
    Cassius, thank you for the response. I actually found a work around by adjusting the Time Tracking. I essentially want bullet-time slow motion within C4D without using AE.
  • Cassius Marques
    May 27, 2015 at 8:09 pm
    Its a matter of concept, all you need to do is slow down your motion, you don’t have to increase your fps. You won’t EVER be seeing it in 500fps.
