Activity › Forums › Compression Techniques › 484 x 270 compression please help
  • 484 x 270 compression please help
    Posted by Susan Weimer on May 13, 2009 at 4:11 pm
    i was given a 16x 9 .mov clip that is 484 x 270 ( funky i know) I need to put in to DVD. I went to compressor to change the frame size under geometry in change dimension (encoded pixels ) and its not highlighted. Does any one know how i can change this?
    Daniel Low replied 17 years, 4 months ago 2 Members · 3 Replies
  • Daniel Low
    May 13, 2009 at 4:54 pm
    [Susan Weimer] “I went to compressor to change the frame size under geometry in change dimension (encoded pixels ) and its not highlighted”
    From the pop up menu did you choose ‘Custom’
    __________________________________________________________________
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
  • Susan Weimer
    May 15, 2009 at 7:06 pm
    yes i have selected custom
  • Daniel Low
    May 15, 2009 at 9:23 pm
    Does chapter 21 (page 267-272) of the compressor 3 manual not cover what you need?
