  • Posted by Brett Darken on June 29, 2005 at 5:30 pm
    Hello Friends:
    I just imported some DV shot at 48khz onto my timeline and the red audio render line fired up.
    Went into the format info box and found that the newly imported material listed at 48009.2 khz.
    Went then back to the original digitized quick time it’s listed at 48KHZ.
    Any ideas of what has happened and how to lose the render bar and tones? I see nothing listed in the last 3 months of forums ….
    Thank you
    Brett Darken
    Alexander Kallas replied 21 years, 2 months ago 3 Members · 2 Replies
  • Tony Birkholz
    June 29, 2005 at 8:19 pm
    is 48khz, 48009.2 khz rounded down? you may just want to double check your sequence settings.
    tony birkholz
    editor/cameraman (HD)
    tony@winkincproductions.com
  • Alexander Kallas
    June 30, 2005 at 7:04 am
    Did you import from a Canon camera? This interprets audio at a slightly different rate.
    Cheers
    Alexander
