  • Posted by Chris Monico on August 18, 2010 at 5:24 pm
    Is there any way to demux the 4:2:2 X2 signal that is output via the Sony 5800 VTR using Final cut pro with the KONA 3 card?
    I have an HDCAM SR tape that was recorded (supposedly) at 720p 59.94 4:2:2 X2 with the left and right eye Muxed together.
    Any help is appreciated.
    Jeremy Garchow replied 16 years ago 3 Members · 9 Replies
  • 9 Replies
  • Gary Adcock
    August 18, 2010 at 6:23 pm
    >>Is there any way to demux the 4:2:2 X2 signal that is output via the Sony 5800 VTR using Final cut pro with the KONA 3 card?<< The signals on the tape are not MUX'd the configuration is called Dual Stream each is an independent video stream. The Kona 3 card can handle dual stream signal on output with the Cineform Neo 3D codec installed, final cut is not capable of capturing in this manner right now. You will need to capture each of the video streams individually you should use the same TC in and out points for each stream. Use L&T to capture one channel, then use the same settings to capture the other channel ( and make sure to uniquely ID as R or L!!!!) gary adcock Studio37 Post and Production Workflow Consultant Production and Post Stereographer Chicago, IL https://blogs.creativecow.net/24640
  • Chris Monico
    August 18, 2010 at 6:25 pm
    So, on the deck HD-SDI out 1 is one stream, and HD-SDI out 2 is the second stream? I understand, but how do I know which is left eye, and which is right eye?
    Thanks for responding to my post, and helping me understand this.
  • Gary Adcock
    August 18, 2010 at 6:31 pm
    How should I know? – the tape should be marked- and if not you need to double what ever you are charging, if they did not even both to indicate tracks- you are going to have a ton of correction to do in post.
    My first guess would be to look at the slate info, second guess would be to check and see if one of the camera images is flopped- that would indicate and over under rig and the top ( flopped) camera is usually the left I
    gary adcock
    Studio37
    Chicago, IL
  • Chris Monico
    August 18, 2010 at 6:37 pm
    Unfortunately, I’m in a situation where I cannot double charge anything. I’ve been given the elements and expected to put the pieces together with no issues.
    As far as the content, it’s a baseball game and there isn’t any type of slate information….I’ll figure it out.
    Thanks again for all the help.
    August 18, 2010 at 6:54 pm
    [Chris Monico] “As far as the content, it’s a baseball game and there isn’t any type of slate information”
    But who’s on first?
  • Chris Monico
    August 18, 2010 at 6:57 pm
    Mark Teixeira!
    August 18, 2010 at 7:11 pm
    Naturally.
    https://www.youtube.com/watch?v=sShMA85pv8M
  • Chris Monico
    August 18, 2010 at 7:44 pm
    Is that in 3D?
    August 18, 2010 at 7:45 pm
    4:4:4 x2. 1080p120Hz. Yep.
