420/30p via Log & Transfer reads in FCP as interlaced, fast fix?
Don’t shoot it very often at all, but just noticed that 420/30p via Log & Transfer reads in FCP as interlaced footage. Shows artifacts in Canvas. If I go into clip properties & change to None (interlacing) and re-edit the clip into timeline, it shows as progressive. NOTE: I’ve tested another suggestion that it’s only necessary to ensure the timeline is set for 480/30p, but from what I can see, it’s required to set the clip properties as well.
**BUT**, I can’t find any way to do change properties of more than one clip at a time! And no options on Log & Trans for this.
Thoughts on how not to spend a morning clicking on clip properties?
“Constituo, ergo sum”
Bob Woodhead / Atlanta
http://www.CoolNewMedia.net
Quantel-Avid-FCP-3D-Crayola
Panasonic HPX500
