Activity Forums Adobe After Effects 3D layer order problem
  • Tim Whalen
    February 13, 2012 at 2:37 pm
    Ooh! Please do!
    BTW — I cam across this little tidbit:
    https://www.motionscript.com/design-guide/invisible-facing-away.html
    I think this expression could be used to hide layers that are popping out of place, although I don’t understand the code enough to modify it for my purposes. Your tutorial wouldn’t happen to utilize anything like this, eh?
  • Tom Gomez
    February 13, 2012 at 4:56 pm
    This thread has lots of great points on this topic:
    https://forums.creativecow.net/thread/2/1014011
    YOU can help save TimeSpace. Join the Chronos Protectorate!
    https://www.95ers.com
    https://www.SpaceAceMedia.com
  • Doog Vandi
    March 16, 2012 at 10:07 pm
    @Mark Pyper fantastic. That was it.. in fact the problem started occuring, as soon as I tried to enable layer styles.
  • Doog Vandi
    March 16, 2012 at 10:10 pm
    Try @Mark Pyper suggestion about Layer Styles. Despite there being no layer styles, just turning off the “eye” next to layer style worked.
  • Rob Mclendon
    January 31, 2013 at 7:43 am
    This fixed the problem (layer order taking precedence over z-space) for me. Thanks!!!
  • Shirin Tag
    May 25, 2016 at 9:23 am
    Hey everybody, I have a problem to import a obj file in After Effects.
    The file has a lot off layers and importing it in After Effects, the layers join together and that means I can’t give different texture to each element. Do you have any solution for it?
    I search long for a solution but I still didn’t find it. Any suggestions would be helpful. Thanks
    Ps.I am using After Effects CC Version 13.7.0.124
  • Jared Isham
    May 25, 2016 at 3:44 pm
    To have access to layers of an obj file in After Effects I believe you need to open the file in Cinema4D Lite (bundled with AE now). You can apply your textures in there.
    The other option, I believe, is to use Video Copilot’s Element 3D.
    Unfortunately, After Effects does not support 3D objects natively…as far as I know.
    Jared Isham
    Stage Ham
    https://www.stgham.com
    https://www.jaredisham.com
    film. video. web media
Page 4 of 4
