Activity Forums Apple Final Cut Pro Legacy 3840×2160 (16:9) 25 fps 604 MB/sec CODEC?????
  • Hilary Koob-sassen
    May 13, 2008 at 9:20 pm
    Dear Gary,
    Thanks for that clear suggestion. I will try to up it from 64 (current) to 128 (yikes i think the max block size!)
    see if it plays a few more frames.
    all the best,
    H
  • Gary Adcock
    May 13, 2008 at 11:10 pm
    [Hilary Koob-Sassen] “Thanks for that clear suggestion. I will try to up it from 64 (current) to 128 (yikes i think the max block size!) “
    wasn’t clear enough since I was talking about the AJA tool and setting the file size to be 1 or 2 gigs so that you have a better understanding of how fast the drives will run with your media at the size that it is. you have to look at the graph with the aja system test- it will give you a line indicating the optimum data rate.
    This would be vastly simpler if you were accustomed to working in a frame based workflow- which is VERY common for frames this large.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    May 13, 2008 at 11:38 pm
    Ah! I thought you meant stripe size… yes have been running the test with a 4gb file…. the disk is wicked fast 720 MB/sec in raid 6!!! but it is the frame size/codec thing, i think…
    I am anxious to try your frame sequence test towards previewing full res/25fps…
    I export a series of stills frm FCP timeline at 3840×2160
    export to what format, please?
    I bring this sequence into AE 3840X2160 (8bit only)…and render as…?
    or RAM preview?
    Just clue me to basic moves and settings and formats please and I try with AE5.5 tommrrow…
    Very greatful,
    Hilary
