  • Posted by Randy Johnson on March 22, 2007 at 9:59 am
    Again I am struggling with this odd size. Since I cannot export this size directly to m2v I am going to crop my picture and proxy them together in Watch Out…still I need to edit in this great big size.
    So I have cut my piece in a normal HDV 50i timeline. Now I want to see what it will look like with 3500*768, So i created a custom settings timeline….Here is wheere I am uncertain…please let me know if there is a better way…
    Frame size- 3488*768 (custom)
    Pixel Aspect Ratio- square
    Field Dominance- Upper
    Timebase- 25
    Quicktime video settings compressor: HDV 1080i50 (this is the one that I am not sure what use)
    Randy
    Rafael Amador replied 19 years, 6 months ago 3 Members · 2 Replies
  • Paul Dickin
    March 22, 2007 at 10:16 am
    Hi
    Since HDV is by definition an anamorphic non-square pixel codec it won’t work, I guess.
    I expect you will have to choose a codec that has no implied pixel dimensions.
  • Rafael Amador
    March 22, 2007 at 11:24 am
    I think that if you open a sequence with the setting that you use for editing HDV and them you change the Frame Size should work.
    I think you can get a MPG2 with those dimension with Cleaner. The problem is how to play it later. I don’t think QT can do it.
    Cheers,
    rafael
