  • Posted by Randy Johnson on March 15, 2007 at 1:49 pm
    I am exporting a project that is 3500*768. I have no problems exporting as animation but I want to be exporting to Mpeg 2 since the program I am moving specifys it. Is this a possablity with compresser or fcp export options??
    Randy
    Paul Dickin replied 19 years, 6 months ago 5 Members · 4 Replies
  • Walter Biscardi
    March 15, 2007 at 2:02 pm
    Use Compressor and select any of the MPEG-2 options.
    Walter Biscardi, Jr.
    https://www.biscardicreative.com
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    “I reject your reality and substitute my own!” – Adam Savage, Mythbusters
  • Paul Nevison
    March 15, 2007 at 2:15 pm
    I have a feeling that MPEG 2 files are locked to standard 720×480 NTSC or 720×576 PAL. I dont think MPEG2 supports custom sizes it’s a restricion of the codec, that’s what i’ve found when using cleaner anyway.
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 5.9
    PAL Land
  • Enge
    March 15, 2007 at 3:44 pm
    I’ve had that myself. If you select an M-PEG2 codec, you do not get any other options for frame sizes. I think compressor imagines that you are compressing for a ‘telly’ so it will only give you PAL or NTSC scanning standards. Not much help I know, but it ain’t you…
  • Paul Dickin
    March 15, 2007 at 5:37 pm
    Hi
    I think MPEG-2 requires frame pixel dimensions divisible by 16, so 3500 isn’t a valid size for an encode.
