Activity Forums Adobe After Effects (33::44) Missing frames on afx import
  • (33::44) Missing frames on afx import
    Posted by Mr Toobs on September 11, 2007 at 6:36 am
    I have images with clipping paths that were created in illustrator CS2 which will import into After FX 6.5, but when trying to import into After FX 7 I get the error message
    “After FX warning the sequence has 23 missing frames. (33::44)”
    Does anyone know what this means.
    Cheers
    Mr Toobs replied 19 years ago 2 Members · 2 Replies
  • Steve Roberts
    September 11, 2007 at 11:59 am
    Ususally, that happens when AE thinks you want to import a sequence: file001.ai, file002.ai, and so on … but the error occurs when there are no files between file001.ai and file024.ai.
    Are you importing images numbered in a similar way? If so, make sure that “Illustrator sequence” or “image sequence” is not checked.
  • Mr Toobs
    September 11, 2007 at 9:03 pm
    Ok That solved one part of my problem,
    Now the AI file is coming in but the layers that are images with a clipping path seem to be blank in AFX7, though it works fine in AFX 6.5!
    I have checked out the files in Illustrator and they seem to be fine, I can’t seem to work out how the flatten an image and clipping path in Illustrator without flattening the whole document
