Activity › Forums › Adobe After Effects › 32 bpc
32 bpc
Posted by Jim Wilcox on April 27, 2006 at 6:47 pmEvery time I try to fire up AE 7 and change to 32 bpc the program just crashes. Running G5 Quad. Any suggestions?
Andrew Kramer replied 20 years, 4 months ago 2 Members · 3 Replies -
Andrew Kramer
April 27, 2006 at 6:57 pmBe sure to be in “adaptive resolution” no openGL works with 32bpc.
Hold down caps lock until it switchs then turn off the caps lock.Reset prefs.
Hard to say really…
Andrew -
Jim Wilcox
April 27, 2006 at 8:03 pmDidn’t know about needing to hold down caps lock when switching to 32bpc. What’s up with that? Does work, however. I was already in adaptive res.
Andrew Kramer
April 27, 2006 at 10:15 pmIt’s not a real fix. I just know sometimes when using effects or procedures that are heavy that sometimes helps.
Andrew
