Activity › Forums › Apple Final Cut Pro Legacy › 28:15:23 long time line gains 6 frames in Quicktime
  • 28:15:23 long time line gains 6 frames in Quicktime
    Posted by Jack Fox on January 10, 2009 at 3:52 pm
    When I Export a Quicktime Movie from FCP it gains 6 frames according to Quicktime Player. If I import the same file back into FCP as a movie file it is at the correct length. The sequence and the export are 23.98 fps. Below are my sequence settings. Note that the fps is “Custom” and the fps is 23.976. I’m not sure where that came from, but my capture source was 24p. Please advise.
    jmf
    Jack Fox replied 17 years, 8 months ago 3 Members · 3 Replies
  • Sean Oneil
    January 12, 2009 at 8:18 am
    Sounds like QT is misinterpreting the length. If you can’t actually identify an extra 6 frames, then there’s probably nothing to worry about.
    Sean
  • Tom Wolsky
    January 12, 2009 at 8:37 am
    23.976 is the true frame rate of 24p in video. FCP rounds it up to 23.98, but it is actually 23.976.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop”
  • Jack Fox
    January 13, 2009 at 1:24 am
    Here’s what I get from the uplink editor:
    -These are supposed to be 26:46. Episode 2001 is 26:47:20. In the world of automation, many stations record for the exact length of time listed, the program will be downcut.
    jmf
