Activity Forums Apple Final Cut Pro Legacy 24.98 & 24.99 instead of 25 fps – what the heck?
  • 24.98 & 24.99 instead of 25 fps – what the heck?
    Posted by Serj Kasparoff on July 11, 2014 at 12:46 pm
    Hi all
    I need to capture an old DVcam’s, and i’ve set up FCP7 to capture it in PAL 25fps, but QT shows the captured clips as 24.98 & 24.99 fps instead of 25, while VLC and FCP sequence settings shows it as 25.
    Need i worry about it?
    Any suggestions?
    Serj Kasparoff replied 12 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    July 11, 2014 at 4:51 pm
    Quicktime frame rate reporting is bullocks…crap. Don’t believe it. Trust what FCP is telling you.
    Shane
    Little Frog Post
    Read my blog, Little Frog in High Def
  • Serj Kasparoff
    July 11, 2014 at 5:21 pm
    thanks, Shane
    Hope you’re right : )
