Activity Forums Adobe After Effects 24,000 fps, 23,98fps or 23,976 fps?
  • 24,000 fps, 23,98fps or 23,976 fps?
    Posted by Cyrus Smith on June 18, 2011 at 6:49 pm
    Which one frame rate has to be used for a high quality master copy of a short film (an uncompressed .mov in a Hard Disk) ?
    Master Copy has to be the starting point for DCP (Digital Cinema Packaging, 24,000?) and Blu Ray (23,976??).
    I cant figure out the right framerate. (The original footage is AVCHD 25fps but I want to convert it in 24p to achieve “film look”)
    so correct master copy 24p is…
    24,000 fps
    23,98 fps
    23,976 fps ???
    Russell Lasson replied 14 years, 10 months ago 4 Members · 6 Replies
  • Todd Kopriva
    June 18, 2011 at 8:29 pm
    23.976fps is the correct video frame rate. ‘23.98’ is just a shorter (and sloppier) way of representing ‘23.976’; the real number is still 23.976.
    23.976fps is used because it is very close to 24fps (the film frame rate), but it can be used by means of pull-down on equipment that was designed for 29.97fps NTSC video.
    Note that 23.976 = 24 * 999/1000, just like 29.97 = 30 * 999/1000 .
    Todd Kopriva, Adobe Systems Incorporated
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Cyrus Smith
    June 19, 2011 at 1:25 am
    Thanks. I typed 23,98 along with 23,976 because it is the frame rate that I read in specifications of iTunes HD Trailers.
    Well, that said, due to its destination for cinema projecting in DCP, and its mastering in Blu Ray (no one NTSC-based destination), which framerate have I to render the uncompressed .mov? 23,976fps or 24,000fps?
  • Walter Soyka
    June 19, 2011 at 6:30 pm
    [Matteo Ferreccio] “due to its destination for cinema projecting in DCP, and its mastering in Blu Ray (no one NTSC-based destination), which framerate have I to render the uncompressed .mov? 23,976fps or 24,000fps?”
    I believe that DCI-compliant DCP must be 24.0 fps. In my experience, Blu-ray is usually 23.976, but could be either. I have a US/NTSC frame rate bias.
    You should check deliverables requirements with whomever is handling the DCP and Blu-ray production.
    Walter Soyka
    Principal & Designer at Keen Live
    RenderBreak Blog – What I’m thinking when my workstation’s thinking
    Creative Cow Forum Host: Live & Stage Events
  • Todd Kopriva
    June 19, 2011 at 6:31 pm
    As usual, Walter is correct on all points.
  • Cyrus Smith
    June 19, 2011 at 8:38 pm
    [Todd Kopriva] “As usual, Walter is correct on all points.”
    Yeah, well i’ll go for 24,000 fps. Thank you both very much for sharing your experience, bye!
  • Russell Lasson
    August 12, 2011 at 2:56 am
    I know it’s probably too late now, but I would suggest using 23.976 as the master. It makes things more compatible with NTSC broadcast. I create a lot of DCPs and the conversion from 23.976 to 24 is easy to deal with. But burning a 24fps blu-ray or dvd instead of a 23.976 fps version can cause problems.
    Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
