Activity Forums Maxon Cinema 4D 23.978fps in Cinema 4d
  • 23.978fps in Cinema 4d
    Posted by Christian Remde on April 29, 2008 at 2:48 pm
    Hi,
    I’m trying to set the frame rate in Cinema 4D to 23.978 but I can only get either 23 or 24fps…is there something that I’m missing?
    Christian
    Adam Trachtenberg replied 18 years ago 2 Members · 1 Reply
  • Adam Trachtenberg
    April 29, 2008 at 3:32 pm
    You’re not missing anything — Cinema can’t do fractional frame rates. Generally the .022 fps difference isn’t a problem but if you have a longer piece you may have to re-time the Cinema footage a little in post.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
