Activity Forums VEGAS Pro 2:17:00 too long for a standard DVD??
  • 2:17:00 too long for a standard DVD??
    Posted by Dan Myers on January 23, 2012 at 10:32 pm
    I have a video that is 2 hours and 17 minutes long and do not want to split it into two parts. I am going to use Variable Bit Rate, but the calculator that I use (that I got from a recommendation here) says the quality is around 43% and falls near the bottom of the good quality range. The VBR values are
    Min – 2,550,000
    Avg – 4,264,000
    Max – 7,450,000
    Do these sound like they will work out OK? I have never used a VBR without a max of 8,000.000.
    Any thoughts?
    Thanks. Dan.
    Dan Myers replied 14 years, 7 months ago 5 Members · 6 Replies
  • Stephen Mann
    January 24, 2012 at 1:07 am
    Every project is different and you won’t know until you encode it and burn a test DVD. If your video has a lot of static shots, then it will keep to the average bitrate and look pretty good. If there’s a lot of changes from frame-to-frame or lots of movement in the scenes, it’s going to look bad.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Mike Kujbida
    January 24, 2012 at 2:54 am
    I once burned a 2.5 hr. video (theatre play) to a single layer DVD and the quality was fine.
    As Steve said, it all depends on your source video.
    Mine was well it and shot with a 3 chip camera with 1/2″ CCDs so I had great quality to begin with.
    I selected a small portion of the play (darkest section with a lot of motion) and rendered this to see what the final would look like before I committed to the full render.
    Make sure to do it as a 2-pass encode as this will help to maximize quality.
  • Nigel O’neill
    January 24, 2012 at 3:10 am
    Personally, for content that long, I would either split it into 2 discs or consider using a dual layer disc.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Ted Snow
    January 25, 2012 at 5:22 am
    I too, like Mike, have shot and put 2.5 hours on a single DVD. My footage was a memorial service shot with a Sony VX2100 inside a church during the day with plenty of light and also the graveside service. There were a few long winded speakers that spoke at the service.
    I rendered with a single pass VBR using a bitrate calc. I was concerned at first about the quality since the footage was so long but it turned out great. There was even a spinning ceiling fan that was in view and it looked very natural.
    I usually don’t like to put more than 2 hours on a disc but this instance turned out fine.
    edited to add:
    With this being a memorial service, my camera was on a tripod and there was not much moving other than an occasional zoom in and out.
    ASUS P8P67 Deluxe MB
    EVGA GeForce GTX 560 Ti 1 GB DDR 5
    Intel i7 2600k 3.4 Ghz
    Corsair HX750 power supply
    Two Seagate Barracuda 500g SATA III drives
    16 Gig G.Skill Ripjaws DDR3 1600
    Canopus ACEDVio card
    Thermaltake V9 BlacX Edition case
    Xigmatek Dark Knight CPU Cooler
    Win 7 Pro
    VEGAS 8.0
    VEGAS 11.0 32 & 64 bit
    Sony VX2100
    Sony HVR-Z7U
    Sony HDR-CX130
    Alesis HD24
  • Nigel O’neill
    January 27, 2012 at 3:28 am
    Yeah, if it is a mostly static scene, VBR works really well and you can get 2+ hours of footage on a DVD. If it was a football game, it would turn out terrible and blocky with motion artifacts that are obvious.
  • Dan Myers
    January 27, 2012 at 12:57 pm
    Hi all,
    Thank you so much for your responses. I was fortunate that, like Mike, it is a school play and mostly static and the quality looks pretty good.
    Dan.
