Activity › Forums › Adobe Premiere Pro › 1920*1080 slideshow sequence settings
  • 1920*1080 slideshow sequence settings
    Posted by Maurice Mahady on October 17, 2010 at 12:33 am
    HI, trying to create a slideshow in ppro cs4.2.
    The final output will be on a 1920*1080 projector so Ive resized all the images to match these dimensions prior to importing.
    When starting a new sequence the only options for full HD are in the AVCHD or AVCIntra. Ive tried both these but the output is always somewhat jerky especially with rolling titles and default cross dissolve transitions.
    Before I get to involved in the AME settings can anybody suggest a good starting point for the sequence settings?
    thanks
    Maurice
    Bob Dix replied 15 years, 11 months ago 2 Members · 1 Reply
  • Bob Dix
    October 17, 2010 at 1:54 am
    Mauricem,
    This may or may not help.
    Bob
    Re: importing and exporting stills, 1920 x 1080, and 1280×720
    This is our method of working it may not
    suit you.>
    1000 + Stills taken on a Canon 5D mark II of Tibet and China as back up to High definition Video from same camera for promo .Camera set at sRAW2 2784 x 1856 pixels. >
    Converted to High quality JPEG in Canon Professional Digital > open files in Photoshop reduce size oi 1800 pixels in width to fit safety frame in PP monitor >Using Process Multiple Files > by doing this you wil be full frame & not cut ends of the images off , unless that is what you prefer.
    Open files by Import into PP Automate to Sequence >set at 100frames. dissolve transitions set to 30 frames overlap, 1000 is done in say 30seconds, edit as required> add background audio etc.
    Render timeline > EXport to Tape as Cineform HD avi, tick box to generate m2t/HDV file which could be used later as burn to Blu-Ray. The results are HD and stunning. Remember anything altered in Photoshop or Premiere will alter in other program .
    The preset in PAL @25fps is Editing Mode is HDV playback>HD Anamorphic 1080i Ratio 1.333> upper field First>25fps timecode 48,000Hz Audio Samples.Frame Size 16:9 > OK
    It will transcode., you must save m2t file after box opens at successfull render otherwis you will need to do it all over again if you are exporting to Tape. PP should automatically activate the receiving VTR Camcorder.
    Good luck, we have used this method 200+ times the results in High definiton are stunning on a Sony Bravia Full High definition TV 1920 x 1080i @46″
    Freelance Imaging & Video
    AUSTRALIA
