Activity Forums Panasonic Cameras 1700 Deck Upconvert (follow up)
  • 1700 Deck Upconvert (follow up)
    Posted by Blake Calhoun on February 9, 2006 at 1:38 am
    Anyone acquainted with the Panny 1700 HD deck know how to get it to upconvert 720p24 to 1080p24? I’ve gone through the manual and see it mentioned as a capability, but no where does it say how.
    If you switch the deck system to 23/24hz does it “auto” upconvert the 720p24 footage?
    I’m digitizing into a 1080p23.976 Avid DS project and I can “see” the footage, but I’m having trouble knowing if it’s correct or not (partly because the DS won’t capture right now – still trying to figure that out too, but that’s for another forum). 🙂
    Blake
    “Killing Down”
    http://www.killingdown.com
    Blake Calhoun replied 20 years, 6 months ago 2 Members · 2 Replies
  • Jeff Merritt
    February 9, 2006 at 11:37 pm
    Hi Blake,
    Please take a look at Page 80 of the AJ-HD1700 Opertations Manual and you will see you can change the System setting to 23/24 from 59/60. Do that. When you do, the machine will automatically convert the 720p/24 to 1080p/24 on the output HD-SDI. This is really 23.98 Psf. This same function is also available on the AJ-HD1200A in the System menu.
    Incidentlally, if you playback AG-DVX100 or AJ-SDX900 footage acquired at 24 FPS, you will get the same result, only up converted from SD to HD.
    Good luck.
    Jeff Merritt
    Product Line Business Manager
    High Definition Products
    Panasonic Broadcast
    323-436-3676
  • Blake Calhoun
    February 11, 2006 at 7:12 pm
    Excellent! Thank you for the info. I was hoping that was the case. I’m back in the edit suite on Monday and will give it a try.
    Thanks again,
    Blake
