14.985 fps footage, 29.987 fps output
Hi, new to this site.
I just received some 14.985 fps footage from a client, and I need the output to be 29.987fps. I’m working on a macbook pro with OSX 10.9.5, and working in After Effects CC.
I looked at some other forum posts about interpreting the footage differently, and tried some different things but couldn’t get anything to work.When I first imported the footage, I got an error message about “overflow converting ratio denominators”, so I did as a tutorial said and rounded the fps up to 15. And then I made the fps in my comp 15 as well. This only slows down the footage, and the audio for it is no longer aligned.
Does anyone know the best way to handle this frame rate conversion?
Joey
