Activity Forums Apple Final Cut Pro Legacy 1.33 Vertical squeeze
  • 1.33 Vertical squeeze
    Posted by Abba Kido on May 2, 2011 at 4:08 pm
    Apologies if this is a common/ or obvious question…
    Without fully aware as to why, i’m being asked to ‘crop’ 1080i footage into 4:3, and then to add a 1.33 vertical squeeze. Could you please explain how i could go about this in fcp?
    Thanks.
    Greg Baldi replied 15 years, 4 months ago 3 Members · 2 Replies
  • Andrew Rendell
    May 2, 2011 at 5:40 pm
    It doesn’t make much sense to me – crop implies that you have to lose the sides of the picture, then the vertical squeeze implies changing the geometry of the pictures… however, what I think they might mean is putting the 16:9 image in a 4:3 frame in “letter box” style, i.e., with black bars top and bottom. I used to do that occasionally when it was SD 16:9 and the client wanted to view stuff on a PC with an older media player that didn’t recognise stretched pixel aspect ratios, but 1080i is square pixels (so the issue of displaying non-square pixels doesn’t arise) so it’s only a guess.
  • Greg Baldi
    May 2, 2011 at 8:53 pm
    My first thought was that they need the final in a low resolution with a widescreen effect but when I read “Crop” and “Squeeze” I fell off my editing chair. Sounds like a messy request. Let us know what happens.
    -Greg Baldi
    Post Production Editor
